Старый 06.10.2011, 14:50   #24
YesYes
Аватар для YesYes
Авто: XL 3.0 S11 black
Восклицание много-всяко
Сообщение от slashx Посмотреть сообщение
И так постоянно
Почитал сервис мануал на досуге.
Нашел там в разделе 51 -EXTERIOR > WINDSHIELD WIPER AND WASHER > ON-VEHICLE SERVICE > LIGHTING CONTROL SENSOR >
LIGHTING CONTROL SENSOR (RAIN SENSOR) ADAPTATION
следующие слова:
LIGHTING CONTROL SENSOR INSTALLATION
caution: After executing the lighting control sensor (rain sensor) adaptation, do not touch the lighting control sensor (or do not move it from the fixed position).
-Mount the lighting control sensor onto the optical coupler, and then connect the connector.
- when the lighting control sensor is pushed to check the installation condition, install the connector and the lighting control sensor cover and wipe the windshield thoroughly. When the windshield is dry, execute the lighting control sensor (rain sensor) adaptation. <Refer to GROUP 51 - Lighting Control Sensor (Rain Sensor) Adaptation >.
note: Be careful not to touch the lighting control sensor receiver. (The lighting control sensor receiver has limited resistance to oil.)
Что вкратце говорит - после снятия \ установки датчика - требуется калибровать датчик с помощью дилерского сканера MUT-III:
1.caution
Before performing the adaptation, check if the lighting control sensor (rain sensor)-related diagnosis code is set. (if set, refer to GROUP 54A, HEADLAMP DIAGNOSIS CODE CHART ).
Turn the wiper switch to the OFF position.
2.Clean the windshield in fine weather.
3.Wipe the surface of the windshield thoroughly, and check that the surface is dry.
4.Turn the ignition switch to the ON position.
5.Turn the ignition switch to the LOCK (OFF) position.
6.caution Before connecting or disconnecting M.U.T.-III, always turn the ignition switch to the LOCK (OFF) position.
Сonnect the M.U.T.-III to the diagnosis connector.
7.Turn the ignition switch to the ON position.
8.Wipe the windshield surface of the lighting control sensor section thoroughly, and check that the surface is dry.
9.Select "LIN" on the "System Select" screen, and press the "OK" button.
10.Select "Rain light sensor" on the "System Select" screen, and press the "OK" button.
11.Select "Special Function" on the "Rain light sensor" screen.
12.Select "Rain Sensor Adaptation" on the "Special Function" screen.
13.Press the "OK" button, and execute the "Rain Sensor Adaptation."
14.Press the "OK" button after the execution screen is displayed.
15.Press the "OK" button after "Completed" is displayed.
ИТОГО: получается, что если датчик трогал\сниал - надо калибровать. И замена стекла с датчиком дождя становится более затратной процедурой. Думаю что официалы эту операцию делают, а вот "вася-гараж" как минимум без оборудования и не в теме. С другой стороны.... может не у всех так глобально при смене в "вася-гараж" невезет... И в первую очередь это просто зависит от стекла\качества изготовления.
в pdf-ках выжимки по данному вопросу.
Тип файла: jpg ls1.jpg (167.6 Кб, 505 просмотров)
Тип файла: jpg ls2.jpg (100.6 Кб, 512 просмотров)
Тип файла: pdf light-contr.pdf (201.2 Кб, 39 просмотров)
Тип файла: pdf Pages 1-40 from LS.pdf (1.34 Мб, 36 просмотров)
Тип файла: pdf Pages 41-71 from LS.pdf (1.25 Мб, 29 просмотров)
XL 2010 - Доустановка ПТФ андрей393 Outlander XL. 2010. Jet fighter grill - Эксплуатация и дополнительное оборудование 16 26.11.2015 15:40
XL - Доустановка датчика света feniksdsn Outlander XL - Эксплуатация и дополнительное оборудование 28 07.04.2014 14:24
Airtrek. Датчики дождя и свет Жуков Денис Николаевич Airtrek - Запчасти и дополнительное оборудование 44 26.07.2011 15:52
Глухой стук в задней подвеске после дождя marfik Outlander XL - Запчасти и ремонт 3 03.05.2011 21:52
датчик дождя? DaVinci Outlander - Эксплуатация и ремонт 8 28.07.2008 18:01
Текущее время: 04:21. Часовой пояс GMT +3.
