Start reading DB...
05.11.2015 15:25:24 - Reading OK
05.11.2015 15:25:24 - Press Decode V
05.11.2015 15:25:24 - Decoding: 84103305181351086B004105409011111D8021BA28AF72B0AC92E9156A008242E42121432090AB0900005181 EDV=13
05.11.2015 15:25:24 - Press Decode C
05.11.2015 15:25:24 - Decoding: 112032100122121FF00F0F3F1F0FFFFF0F100F0F2FF1FF
05.11.2015 15:25:24 - Press Decode M
05.11.2015 15:25:24 - Decoding motor: 8410030070040100086B092F00000001A001A015
05.11.2015 15:25:35 - Press Encode C
05.11.2015 15:25:35 - LengthMatrixCustom=41
05.11.2015 15:25:35 - Coding: 112032100122121FF00F0F3F2F0FFFFF0F100F0F2FF1FF
05.11.2015 15:25:36 - Press Write Custom
Try write is 112032100122121FF00F0F3F2F0FFFFF0F100F0F2FF1FF
05.11.2015 15:25:37 - R/W error 22 - conditionsNotCorrectOrRequestSequenceError
05.11.2015 15:25:40 - Press Compare
05.11.2015 15:25:40 - Compare custom codings:
05.11.2015 15:25:40 - 1. 112032100122121FF00F0F3F1F0FFFFF0F100F0F2FF1FF
05.11.2015 15:25:40 - 2. 112032100122121FF00F0F3F1F0FFFFF0F100F0F2FF1FF
05.11.2015 15:25:40 - Decoding: 112032100122121FF00F0F3F1F0FFFFF0F100F0F2FF1FF
05.11.2015 15:25:40 - Found 0 distinction(s)
05.11.2015 15:25:40 - Press Decode C
05.11.2015 15:25:58 - Press Encode C
05.11.2015 15:25:58 - LengthMatrixCustom=41
05.11.2015 15:25:58 - Coding: 112032100122121FF00F0F3F2F0FFFFF0F100F0F2FF1FF
05.11.2015 15:25:59 - Press Write Custom
05.11.2015 15:25:59 - R/W error 22 - conditionsNotCorrectOrRequestSequenceError
05.11.2015 15:26:01 - Press Compare
05.11.2015 15:26:01 - Compare custom codings:
05.11.2015 15:26:01 - 1. 112032100122121FF00F0F3F1F0FFFFF0F100F0F2FF1FF
05.11.2015 15:26:01 - 2. 112032100122121FF00F0F3F1F0FFFFF0F100F0F2FF1FF
05.11.2015 15:26:01 - Decoding: 112032100122121FF00F0F3F1F0FFFFF0F100F0F2FF1FF
05.11.2015 15:26:01 - Found 0 distinction(s)
05.11.2015 15:26:01 - Press Decode C
05.11.2015 15:26:04 - Press Encode C
05.11.2015 15:26:04 - LengthMatrixCustom=41
05.11.2015 15:26:04 - Coding: 112032100122121FF00F0F3F1F0FFFFF0F100F0F2FF1FF
05.11.2015 15:26:05 - Press Write Custom
Try write is 112032100122121FF00F0F3F1F0FFFFF0F100F0F2FF1FF
05.11.2015 15:26:06 - Press Compare
05.11.2015 15:26:06 - Compare custom codings:
05.11.2015 15:26:06 - 1. 112032100122121FF00F0F3F1F0FFFFF0F100F0F2FF1FF
05.11.2015 15:26:06 - 2. 112032100122121FF00F0F3F1F0FFFFF0F100F0F2FF1FF
05.11.2015 15:26:06 - Decoding: 112032100122121FF00F0F3F1F0FFFFF0F100F0F2FF1FF
05.11.2015 15:26:06 - Found 0 distinction(s)
